I posted this in the wheel/tire forum a few days ago, and completely spaced x-posting it here. So, here...
Maybe a year ago I became aware of a new technology being used to make bicycle spokes.
By and large spokes are made from steel these days, primarily because steel makes for such a great blend of weight, cost, and durability. Experimentation with aluminum and composites has happened and will continue to -- that's how the breed improves.
Spokemakers have, in recent years, embraced straight pull spokes (of steel and aluminum) for reasons of, um, marketing, best I can tell. They haven't been proven to do anything better than j-bend spokes, other than introduce a confounding choice onto an unsuspecting and largely uneducated public. I think the conversation probably went something like this:
Marketing hack A: "How do we sell more of something without actually improving it?"
Marketing hack B: "Divide, confuse, and conquer? Oh, plus new colorways!"
My perspective is that straight pull spokes are a "solution" to a non-existent problem.
Ahem. Did I digress?!
I'm writing today about Berd spokes. You can read their shpiel here -- it's the same stuff I read when I first heard about them. The reading isn't particularly compelling, but it's informative enough if you pay attention. Basically, these spokes knock a good chunk of mass off of any wheel when compared with steel spokes, they don't give up any strength or stiffness in so doing, and they add a measure of dampness to a wheel.
Lighter, stronger, and more comfortable? What's the catch?
Glad you asked. The catch is in cost per spoke, as well as in increased labor time to build each wheel. Which also adds more cost to each wheel. Basically, a wheelset built with these spokes is expensive relative to any other spoke available.
Your next question is undoubtedly some variation on "How much?" immediately followed by "Are they worth it?"
The answers are "quite a bit" and "it depends".
Let's not get ahead of ourselves...
My ears perked up when I learned that the source material is Dyneema, which I know and trust from the HMG packs that Jeny and I have used for years. The stuff is incredibly light and unbelievably abrasion resistant. I know there are a lot of other attributes that are important in a pack, but for me those are the big two. After years and years of abusing our HMG packs -- bushwhacking through alder and devils club in AK, grinding and dragging them through dry scrub oak and wet slot canyons in the Colorado Plateau -- and them being dirty but otherwise none the worse for wear, I've come to think of Dyneema as an incredibly impressive material.
"Sure", you're saying, "for a pack". But, good enough for bicycle spokes?
Read on.
It takes a good chunk longer to build a wheel with these spokes. Some of that is in the lacing process, as the loop at the head of the spoke needs to be pulled through the spoke hole in the hub, and this isn't as easy as it sounds. Then you slip a little 'rod' of Dyneema through that loop, pull the spoke tight by hand, then move on to the next one. It isn't complicated -- is actually anything but -- it just takes a little more time than you're used to. Home builders that love the process of building their own wheels will get to spend more time enjoying that process.
There is additional time required in the tensioning process, because the material these spokes are made from has inherent stretch. Basically you need to bring the wheel up to ~final tension, do some stress relief cycles, tension it again, stress relieve again, tension once more, then hang it up for a few days and let the spokes elongate. You do not finish a wheel built with these spokes in one sitting.
Come back to it a few days later, get it true/round/dished to spec, *then* balance it out at final tension. The guys at Berd will help you with the nuances of your spoke calc, and they'll also provide numbers appropriate to whichever tensiometer you're using. Expect to take 2+ hours on your first one, then maybe a little less on each subsequent. I can't see how you'll ever get build time equivalent to a steel spoked wheel, nor do I think it's important that that happens.
I only have hundreds of miles on these spokes, on two different bikes, so the jury is still out on long term durability. Once I have thousands of miles I'll feel more confident in saying what they can and cannot handle as far as abrasion and impact.
https://vimeo.com/264363354
I did take a sharp shears to one, under tension, just to see how it would react, as sort of a crude abrasion test. It took several hacks at the thin section of the spoke to get it to cut, and even then it wasn't like you could cut immediately through the whole thing -- there were several strands that just wouldn't cut completely without several hacks and a lot of effort. In the video above I am not 'lillydipping' with the scissors -- I'm really cutting hard. The result of this crude experiment is confidence inspiring when considering sharp schist or shale plates that get thrown up, or even just incidental contact with the local square-edged sandstone and granite. Just one indicator, but an impressive one.
The ride is subtly different from anything else I've ridden before. I should clarify that on my first build with these I took an existing wheelset using DT 240s hubs, Derby carbon rims, and DT SuperComp spokes -- a wheelset that I'd ridden over 2k miles already -- and cut out the SuperComps, then relaced with the Berd's. I even re-used the same tires, at the same pressures, such that the only thing that had changed was the spoke material. This single change created a net loss of 110g per wheel. Not a misprint.
I could call them "damp" but you might get the idea that that means "slow". I could call them "quiet" but you might misconstrue that as "muted". Nothing about the ride is extraordinary relative to a normal steel spoked wheel, it's just a little different. I am princess and the pea when it comes to minutiae like this, and it's possible that what I feel when riding the Berd spokes just won't be noticeable to you. Put differently, there is no discernible difference in overall wheel stiffness in any plane, no change in how the overall package handles what you're throwing at it. They are still stiff, strong wheels -- they just got a lot lighter and now seem to absorb more vibration from the trail.
I'm not a hard-core numbers guy so I can't say that they make me feel x% fresher at the end of a ride. And I'm not fast so I can't say they make me faster. But I can say that I like the feel -- enough that I'm lacing another set for myself. The absorption of trail vibrations is noticeable enough that, were I still an endurance nerd out chasing sunsets, I'd emphatically be using these for both training and racing.
I'm building with them for customers effective immediately. Expect to gasp audibly at the price -- $8 per spoke plus extra labor time, on top of hubs, rims, and (probably) shipping.
Don't hesitate with questions.
Read on.
