Has anyone else experienced this?
I am a long time sram user. I have sent box-fulls of broken x-9's, 9.0's, 9.0sl's, x-7's and 7.0's back to sram for negotiated replacements (usually 3 bad for 1 good).
After a good endo, my rear derailler would not shift outbound to the little cogs 6-7-8-9. I played around a little trailside but ended up making due. At home on the stand, I noticed that the parallelogram was hitting the 'bolt onto the frame ring'. It couldn't slide past outbound and if I forced it outbound, it wouldn't shift inbound past this bolt on pivot. I took a dremel and ground enough off the parallelogram bar and the bolt pivot for things to pass normally and all seems OK.
I kind of expected these parts to snap, not bend as has been my experience outlined above.
