bent my #2 gear up front, not a bad bend, maybe 3/16s of an inch or so towards the #1 gear. will the bike gods cry if i just take it off and hammer it back out? is this an immediate replacement kinda problem?
caught! it was indeed during shifting while climbing with my 275 pound clyde self. im still new, and i knew i shouldnt have done it but eh.. was trying to keep up and couldnt stall or i'd have had to hike-a-bikeSquash said:Another thing to consider is why did it bend? If you bashed it into something then okay, but if it bent under shifting or for some mechanical reason you may want to look at the cause. Bending it back is only a temporary fix in that case as the mechanical condition that caused the bend is likely still there. If it was a botched shift then of course the user needs to be adjusted.
Good Dirt
I'd say good idea. At least it worked for my pos FSA crank when I bent the middle chainring. Just pulled the middle ring, got a hammer, and beat it back straight on my dorm room floor. Tested it repeatedly by setting it on a table and looking to see where the bend was. Got it straight after a few tries and put it back on. Its been fine since (well, it still chainsucks pretty bad from time to time, but it did that pretty much from the time it was new). Oh, and I also got out a rattail file and took off some burrs from the teeth.djcornbread said:caught! it was indeed during shifting while climbing with my 275 pound clyde self. im still new, and i knew i shouldnt have done it but eh.. was trying to keep up and couldnt stall or i'd have had to hike-a-bike
i was thinking of placing the single gear between two flat pieces of either wood or metal, whichever i can find, then using a rubber mallet to sandwhich it back flat. good idea or bad idea?
