Bending seatstays under braking
752 Views 4 Replies 5 Participants Last post by  dorsett
I got a sitch with my rear braking I'm not sure if I should be worried about or not. Here's the skinny:
- Bike: 1991 Trek 950 lugged steel frame
- Brake levers: Dia-Compe 287V road brake levers
- Brakes arms: Shimano Deore M510 v-brakes
- Brake pads: Kool-Stop dual compound MTB brake pads
- Wheel: 1991 Shimano Deore LX wheels
Here's the sitch - when I squeeze the brake levers, I notice that the seatstays bend ever so slightly outwards at the v-brake boss point. It's the darnest thing - I've never seen anything like this before. Is this normal, is this an issue with my seatstays, is this a matter of situating my brake pads, what?
If anyone can help shed some light on this and if there's any I can or even should do, it'd be great. Thanks a mil.
1 - 5 of 5 Posts
This is entirely normal. Many manufaturers produce brake boosters that prevent or reduce this effect.
Exactly what I was about to say. I used to run a brake booster on my steel frame because of the flex. Really stiffens things up. When I switched to Magura Racelines on it (when they first came out), a brake booster was almost required, the Maguras would bend the stays even more than cantilevers.
buy a $15 v-brake booster.
Or else don't worry about it, because you barely even need brakes in the NYC area...
I'd like to see more classic hardtails around Blue Mountain; get that thing running!
-rob in Brooklyn
That flex adds a bit of modulation. Hell if it bothers you make a brace, You well get a stronger brake.I know when I used rim brakes thats what I did.
1 - 5 of 5 Posts
