You will not be dissapointed , awesome wheels .
That's who I would suggest for that area. Great guy, knowlegeable, top-notch builds w/ good pricing. frankscyclery.com7daysaweek said:If you're near the triangle area I'd say check out Frank at Franks Cyclery.
+1 A good local builder means not having to ship them back if there is ever a problem. And you build a relationship with a local resource.ncfisherman said:Where are you located in NC? What about using a local builder? Shelling out that kind of money, I always go local(for wheels). There are many good builders in our state.
Good picks on the parts - what spokes will be used? Supercomps?
Actually, the DT hubs are helium-filled and theoretically subtract weight from your bike...jlackey49 said:This is great feedback and I really appreciate it. Sounds like Dave is the man. From what I'm hearing, the No Tubes Crest is the way to go and the discussion is centered around the hub. I think the difference is only about $150 for DTs vs Hope. Will I see any difference in the performance or weight (I have the FRONT Hope II at 185g and the DT 240s at 96g). Does this sound right?
Dude, go talk to Matt or Doug at Ultimate.jlackey49 said:Not cheaper...but will I be able to tell a difference?
ncfisherman - suggestions on local builder?
