Anyone religiously measure your tire pressure after you get done riding? I'm not sure why, but a few rides ago I measured my tire pressure after my ride. Pressure went up about 3 PSI per tire. Outside temperature probably had a little to do with it, but it had only increased about 10 degrees F. I did this again after a ride today. PSI went up about 2 lbs. So I'm setting my PSI at what I think is ideal, then I find myself letting air out midway during my ride. I'm probably going to start setting the PSI lower initially knowing this is happening. Just curious what others have found.
