What's the beefiest 100mm travel fork for 29 inch wheels with boost spacing? I'm a big guy and my bluto isn't going to cut it any longer. Even the Fox 34 I rode on a demo bike didn't seem good enough.
6'4 275 here with a yari on my Krampus. Plenty beefy for my needs.What's the beefiest 100mm travel fork for 29 inch wheels with boost spacing? I'm a big guy and my bluto isn't going to cut it any longer. Even the Fox 34 I rode on a demo bike didn't seem good enough.
I'd be content with a Fox 36. Are you saying I can reduce the travel in the 36 to 100 with an air shaft swap?One simple solution might be the RockShox Yari RC 29+, which is listed with a 100mm travel option.
A more thorough answer is, that: it's not too difficult to reduce the travel on most any fork, so if you truly want the beefiest, it's likely a Fox 40 or other dual-crown. That's probably even beefier than you're looking for but the same is true for most forks, though you may need to be a little creative at finding a non-stock size air shaft (e.g. putting a Pike air shaft in a Lyrik chassis), or comfortable cutting and threading the air shaft.
The 831 airshaft states it's for the 26" version of the fork. Will it work fine in the 29" version of any travel version of the fox 36?Yup, just get the 831 airshaft.
