1 - 3 of 3 Posts
ups and downs
You could contact Enduro about buying their MAX bearings. They don't build a bearing kit for the Switch, but they have a big selection of the bearings. The bearing numbers or sizes might be visible on the bearings, or they may have a list of the ones you need.
http://www.enduroforkseals.com/id169.html
Any of the IGUS bushings are likely easiest to get through a Rocky dealer.
You may be able to address the creaking just by removing the pivot bolts and applying a bit of grease at the metal to metal contact points and putting it back together.
The other really likely place to find a creak is at the shock bushings and reducers.
Loser
Discussion Starter · #3 ·
I've lubed everything and I'm still getting a creak. I'm pretty sure its bearing related - and even if its not, I think 2 years is a good time to go through the bike and replace this stuff. Honestly I don't feel any stiction in the suspension and I don't feel any rough spots when I cycle the suspension without the shock.
Thanks for the info!
John
1 - 3 of 3 Posts
