I'm measuring the gap between the fork and the top of the front tyre. (A 110mm fork can't work with 90mm of clearance)
No matter how hard and often I ram the front wheel down while resetting the bearings, it always comes up as 9cm clearance. If I lower the pressure in the fork so that I can bottom it out, it hits a stop before hitting the front tyre.. so I know it's not a mount/clamp position issue.
Stupid thing is that it's lost this 2cm of travel in just one ride -- a bike path ride at that! -- after getting rebuilt. (I had migration issues before the rebuild and checked it as I left the shop -- 12cm or so of clearance, as you'd expect.) If I have to go get it rebuilt
again... :madmax: fortunately I know the LBS techs fairly well (not so much because they keep having to fix this stupid fork, I ride with them fairly often
Oh how I miss the simple and uncomplicated days of 2001-era electronically controlled leftys, lol
