Hi, I'm looking to replace the bearings in my I9 wheelset. Anyone have any DIY tips on pulling the cartridges out of the hubs?
Thanks.
R
Thanks.
R
Dont know why you had such a problem. I just swapped the QR axle out for the 10mm thru axle the other day. The drive side bearing popped right out with one blow from a rubber mallet.alexalecu said:I had a hell of a time trying to do the same thing on my Hope Pro II rear hub - I even went cave man on the axle with a mallet, trying to make it come out along with one of the bearings, but it didn't work.
I didn't want to buy the special tool for doing this and I didn't want to go to my LBS to let them do it, so I went to Home Depot and bought lots of cheap washers of various sizes and a very long nut (about 2 - 3 inch long), which cost me less than $10 (half of that was the nut alone).
Then, using a quick release skewer and stacks of washers on each side of the QR, I managed to easily extract all the bearings out of the hub and then press the new ones in. The key here is to use washers of the right size (i.e. the ones that support the whole assembly by sitting on the bearings or the hub).
If I wasn't clear enough, I can draw you a picture.
Using the same technique I managed to extract / press the bearings in my BB cups too.
Visual learner here.alexalecu said:I had a hell of a time trying to do the same thing on my Hope Pro II rear hub - I even went cave man on the axle with a mallet, trying to make it come out along with one of the bearings, but it didn't work.
Just what I was looking for. Thanks!
