I searched but found nothing on this topic.
I was thinking one of the very few things people complain about is the adjustments and how the inboard pad is stationary. I personally love the brakes and adjustments are easy but I have a bad habit of fixing what isn't broken.
I understand the amount of "float" isn't that great and using floating rotors would complicate the setup process but it's very doable.
It seems like this would eliminate side to side flexing of the rotor from having to bend to reach the inboard pad. It would also eliminate the slight change in brake feel in between adjustments. In fact this *should* give the brakes a whole new and better feel. You could go longer with no adjustments. I realize this would make the simple turning in of the adjustment knobs a more delicate procedure but it sounds like something that would be fun to try.
So has anyone used this combo before?
