battery pack voltage
629 Views 2 Replies 2 Participants Last post by  slabtown
I have a light (Magicshine MJ-900) and the accompanying Magicshi\ne battery pack that uses 2*18650 LG LI-ion battery cells,7.2V 2.6Ah. I would like to use a different battery pack that takes 4*18650 batteries, and the pack rates at 8.4V (https://amzn.to/3DKgseL). Could the voltage difference in the 2 packs damage the light? Is it ok that the voltages are different? Thanks in advance!
1 - 3 of 3 Posts
no 8.4 is the same, actual running volts will be fine
they are just deriving the numbers from laboratory optimal conditions of fully charged cells
which would be 4.2 volts plus 4.2 volts = 8.4 volts
but 7.2 is it's more like a discharged cell 3.6 + 3.6 = 7.2
so generally if you see 8.4 or 7.2 and it's 18650 or lithium ion....it's the same thing...
two cells in series...or in a 4 banger 2 parallel/2 series
1 - 3 of 3 Posts
