just dinkin around with the settings on my new bike, a '02 rfx w/ '05 pack rear/rockers, a '06 dhxc and a '05 66 rc. i weigh about 160lbs w/o gear, im old and slow and have no big bike experience.
currently i have no psi in the 150mm fork, im close to full open (fast) on compression and i set the rebound up so the tire stays put when i compress and release at static. sag seems to be a issue but maybe thats cuz its not so close to bein broken in. what that means is it doesnt have much right now, maybe 20% at best.
dt sent along a 500lb spring and im runnin 75psi of boost, close to full open (fast) on rebound, pp in the middle and the same for bottom out. sag at 30%. i read this somewhere in here the other day and went for it.
am i remotely close? im under a foot of snow so theres not alot i can do myself. would be sweet to get some baseline ideas for setup. this setup passes the basement test for all you midwesterners btw.
