I have bar ends and like them for some climbs and they offer me a second hand position when I'm riding to the trails or over longer stretches of level terrain.
I ride and race SS too. I have Easton XC riser carbon bars with minimalist bar ends. Do not let the fashion police keep you from putting bar ends on your riser bars. The extra hand positions are very useful on those long rides.the pup said:I do not have them on my current racer (ss) and I miss them! Not only do I use them for climbing but just to have another hand position really helps in longer races. I may just ditch the riser bar and go back to flat bar with barends, but then I lose the 27" width...The quality of my problems have sure improved over the years...
So is lycra (vs baggies)rickm said:I used to use them, but had an encounter with a vine and a tree and had ditch them. Bar ends on riser bars are definately a fashion fauxpau
May I suggest you invest in a Titec Hellbent Flat Tracker handlebar? Same sweep and rise angles (9 degree sweep, 5 degree rise) and same width as a riser bar, without the rise step. Weight is around 180g (or 3/4 of an EA70 riser) for the 7075 version and stronger than a riser also (the bends are the weak points).the pup said:I do not have them on my current racer (ss) and I miss them! Not only do I use them for climbing but just to have another hand position really helps in longer races. I may just ditch the riser bar and go back to flat bar with barends, but then I lose the 27" width...![]()
