1 - 20 of 26 Posts
Hello guys
Has anyone tried these? I am having a commuting bike built with alfine igh and Nitto Noodle Drop Bars, just machined the alfine shifter clamp to fit the larger drop bar dia.
Now I find this, has anyone tried these yet, I'm going to order one and try it on my drop bar.
http://jtekengineering.com/jtek_bar-end_shifter.htm
Or should I stick with the alfine shifter on the top of my drop bar? Anyone have any experience withthat arrgt? It looks different, but doesn't seem too bad. I'll try and post a pic of the alfine shifter on drop bar.
thanks
Klunker2
Steve
Older & Faster...downhill
crisillo said:
can you get enough cable pull from a regular bar end shifter in friction mode?
(I have no experience with the Alfine)
I just researched the heck out of this and the answer I found was, no. Might not be the final answer. I do like that machined piece and would work for the cruiser project, and in black too!!!
Friction shifters are not recommended for geared hubs like the Alfine, without proper indexing, you can place the shift mechanism between gears, which is a good way to terminate the hub.
However, there have been people who said using a Travel-Agent (the pulley used to convert old canti levers to V-brakes) and a Shimano 8-speed shifter works.
http://forums.mtbr.com/showthread.php?t=476936
http://thelazyrandonneur.blogspot.com/2008/08/bar-end-shifters-and-ighs.html
http://www.oldspokeshome.com/blog/?p=119
Keep in mind that 8-speed bar-end shifters typically cost more than the Jtek one.
Personally, I'm surprised that it works (have not tried it yet) since I've found the hub pretty sensitive to correct cable pull, but hey, they say it works!
klunker2 said:
Hello guys
thanks
Klunker2
Steve
Please post a picture.I didn't realize that there was enough aluminum in there to be able to machine them out to roadbar size. Let alone be able to spread them open enough to be able to get them around the curves and bends of a set of noodles. Nice bars BTW.
Super Moderator
yeah.. that was what I guessed behind the question, but I had no real knowledge on it... thanks for the info!
Discussion Starter · #8 ·
Alfine Shifter on Noodle Bars
I will post a pic, the bike is still in the shop I have to bring a camera.
Will try for tomorrow or the next day, sorry for the wait!
Klunker2
Stephen
Looks nice from what I can see.
He is talking about the alfine shifter not the Jtek shifter. I pretty sure it will not fit around the bars even if bored out. I'm definately not a fan of any barend shifter, although I could tolerate a 8speed duraace barend mounted on paul thumbies up on top of the bar. The Jtek is an external clamp, so it will not work with paul thumbies. they should have made it an internal clamp. Even better a brifter or at least figured out a way to make their shiftmate adapter to work.
Banned
I received a testing unit of the Jtek shifter yesterday. Initial feel is that this thing is worth WAY more than they are charging. Very smooth, very positive clicks, well made.
I will post an installation review next week, and I will have it for around 6 weeks, and then I will post a review of how it works.
I will be using it for commuting on a Salsa Casseroll with an Alfine SG-500 hub.
Ride and Smile!
I installed the Jtek bar end last week, pairing it with the Nexus 8 red band. So far only one ride, as I've not had much free time and the bike needs some other work. But my initial reaction is very positive. Shifts are crisp and clean; action feels good. Without a barrel adjuster, initial setup is a little finicky. I did have to reposition the anchor a couple of times to line up the marks just right. I'll be curious to see whether further adjustments are needed.
Apart from that one issue, which isn't the fault of Jtek as I don't see a bar end shifter as the appropriate place for barrel adjuster, I'm perfectly happy with the product based on one 20 mile ride. I'll report back if any problems arise.
Jack
I'm curious if the bar-end shifter from Jtech is indexed or friction?
You can probably get an inline barrel adjuster as used with Shimano STI shifters if you have no other way to adjust cable tension.
Discussion Starter · #17 ·
Alfine Shifter on Nitto Noodle Road bar **Pics!**
Here are some pics of by build with Alfine Shifter on Nitto Noodle Road bar. I haven't ridden it yet, will let you know next week! ASorry for delay, it took a long time to acquire and assemble! Machined the Alfine Shifter to fit the Nitto road bar :
https://s142.photobucket.com/albums/r116/GoHabs1/Steelwool build with Alfine/
Klunker2
klunker2 said:
Hello guys
https://jtekengineering.com/jtek_bar-end_shifter.htm
thanks
Klunker2
Steve
Discussion Starter · #18 ·
Here are some pics, Finally! It worked!
klunker2
Discussion Starter · #19 ·
Here are some pics let me know if the link works! It took a long tome to get the bike built (getting all the parts was a real adventure!)
klunker2
Jack
Have you experienced any problems with the Jtek Bar End Shifter with the Nexus 8 since you installed it a while ago??
1 - 20 of 26 Posts
