I didn't notice it before. But after I started making adjustments to my 5th shock (air pressure, preload, etc), I noticed vertical play when you lift the rear end by the saddle. I don't know if it's from making the adjustments or not. But there's play. Can't tell exactly which pivot it's playing at. All pivot bolts on the shock seem tight, except the main rocker pivot on the seat stay. The main rocker bolt seems to turn freely - that is, turn one side and the other side turns too.
Any Scream owners experience vertical play? Is it normal?
