BANK on it...
1178 Views 13 Replies 11 Participants Last post by  nmpearson
5
Reviews:
1. l dig the design borrowed from the motorcycle style dropouts
2. white-almost pink-red fade = so so
3. LIGHT!!!!
4. complete welding on the down tube gusset
5. 4 sticker options sent with frame: white - black - red - blue
Well done TBC, well done...
1 - 14 of 14 Posts
Interesting. Are the axle holders indexed in any way or are they free to rotate 360 degrees?
360o float, has around a 2mm lip on the outside the axle disc
That is so nice! I wish I could have come over yesterday to peep it.
why are there water drops all over the frame? did you pee on it to mark it yours???
I like the look of that rear drop out system, much better than some of the others out there
Light? how light?
if you wanna change the position of the axle, how can you do it in a perfect measure? in case it get curved for bad adjustment, the lines in the axle are not enough to put it perfect, or is not necessary be that perfect?
Killer tensioning idea. I wish my Mob was like that...
I wondered that too, but it's not that big a deal. I set up my chain so that it's tensioned properly when the notches are in line. It's pretty slick.
I thought there was a reason for not completely welding the DT gusset?
i don't like at all getting the axle system completely perfect. it takes a while, but it does hold well. To be honest, i'd rather just have horizontal dropouts. It would make things a ton easier.
That being said, the frame is like 4.9 pounds and it just way light. i didn't even try and my bike is 26.2 pounds with a argyle, code, saints, and mostly everything else deity. it's been my favorite hardtail i've ever owned. here's a pic
this large we have is 4.12 on the fishing scale +/- 2oz margin of error...
-- Joe Customer is going to build it on his own.
when you change the chain tension, what happens to the rear brake?
do you have to add/remove spacers so it has full contact?
oh yeah it is lighter huh...i just looked on the site, but it says it's 4.7 on the site, so that seems a bit light.
yeah you have to add/remove spacers sometimes but i've only done it once. it's really easy to do.
the bike is just amazing though. it's not the most spectacular dj'er but it works pretty awesome either way
1 - 14 of 14 Posts
