1 - 3 of 3 Posts
just along for the ride
I've been looking to balance out my braking on my up/down type of riding. So the solution has become metallics on the rear and resins on the front, sure beats two fingers on the rear Vee's and 1 on the front! :)
another reason I like my canti brakes
nice thing about canti brakes, you can tune them by varying the length of the straddle cable. lower for max power, higher for a crisper feel but less power. and with grafton and avid levers which I have, and maybe others I don't know about, you can adjust the mechanical advantage of the lever by changing the positon of the pivot, you physically reposition the pin in one of 4 available holes with the graftons, and turn a dial to achieve the same thing with the avids -- well, technically with the avids you're not changing the pivot location, but point at which the cable anchors, which results in the same adjustability. I think Paul's is it? that offered two cable positions with their levers.
I always set my brakes so the front activates with the lever closer to the grip than does the rear, which reminds me not to grab a handful of front lever.
Premium Member
I use metallics on both ends most of the time. I can easily tune the feel/balance of my Avid discs with the red knobs no matter what the pads are.
1 - 3 of 3 Posts
