There's nothing wrong with some oil coming out the air valve. The interior of the air chamber is lubricated with heavy gear oil that's just loose in there. When you don't get any oil coming out, or worse, when you don't see little oil lines on the external shaft, then it's time to do an overhaul and put in some more lubricant The overhauls are quite easy.PAINpusher said:
I didn't know RP3's had a "compression dial" other than the PP lever. You sure you don't mean the rebound dial?
