They put the brace in the back claiming it was stiffer that way. It was the Manitou Black fork that debuted in 2003 that started it. The stiffer claim was never proven and it never really caught on.With disc brakes the fork bridge doesn't have to be in the front.
That said, does anyone know why Manitou put the brace in back?
pic shows a "goofy" Manitou fork (44mm offset), mounted the correct way
Good catch, I missed the brake lever facing that way, the mind boggles. At least it’s an easy fix.I don't disagree with DJ, but once the bars and fork are facing in the right direction the brake lever should be rotated around to the correct position also. It looks like the brake lever is facing in the right direction while the fork, bar and stem are backwards.
I don't have a clue what DCBMX is but it looks to me like the stem and fork are oriented correctly with each other, they just need to rotated 180* so the axle offset is forward and then the bars would need to flipped 180* due to the angle of the grips and then the lever mounted correctly. I'm aware of BMX bikes that can spin the front 360* but those have a special configuration for cables and it doesn't appear that frame is set up for that configuration. Wrong?I can tell you guys don't know anything about DCBMX.
Is this the bike one of the members here just received in the mail?26” BMX Framed twenty6er - $200
Does this count? I'm not a BMX guy but I can't imagine this is correct.
This is correct and basically what I said. The detangler as they are called is not on this bike. The piece that keeps the cables from getting messed up in a 360° rotation. After my post above I realized it didn’t have one but I was correct in saying the fork bars stem are all correct and just need to be spun around and facing the right way. The brake lever however that dbhamner noticed is facing the wrong way. It’s bizzaro 101.I don't have a clue what DCBMX is but it looks to me like the stem and fork are oriented correctly with each other, they just need to rotated 180* so the axle offset is forward and then the bars would need to flipped 180* due to the angle of the grips and then the lever mounted correctly. I'm aware of BMX bikes that can spin the front 360* but those have a special configuration for cables and it doesn't appear that frame is set up for that configuration. Wrong?
