What about a small dry bag strapped to your handlebars with a couple Voile straps?
Good idea, was a bit hesitant to do this as well as i used to run a bar bag but it ripped at the seam during a descent once and all my stuff went everywhere…Maybe a sturdier bag would suffice.What about a small dry bag strapped to your handlebars with a couple Voile straps?
I’ve had good luck using Sea to Summit bags. The Salsa Anything Cradle, Revelate Pronghorn, Rockgeist BarJam, or similar handlebar system would get your bag out away from your cables as mentioned above. I wasn’t sure how much you want to spend to try it out in case you don’t like having a bar bag and want to go with a larger backpack.Good idea, was a bit hesitant to do this as well as i used to run a bar bag but it ripped at the seam during a descent once and all my stuff went everywhere…Maybe a sturdier bag would suffice.
You want micro-panniers. There are several companies that make them. Then simply lash the sleeping bag to the rack in a dry-bag.Anyone tried a system like this? I'm picking it all up for $50 tomorrow. Not sure it will accommodate my sleeping bag but thought I'd give it a try.
