1 - 20 of 22 Posts
I picked up an Ergon this spring and I love it. Most comfortable pack I've used, it really carries the weight on your hips and you can load it up for big days without it feeling like your carrying a heavy pack.
They are expensive and somewhat hard to find reviews on but for me it was well worth it.
Discussion Starter · #3 ·
Nice to hear, thanks!! What about the ventilation... It also works well?? (here in Portugal is veeery hot!!!)
:thumbsup:
Five is right out
I've got a BA3, which has the same harness design.
Compared to a standard pack, the harness is great. It gives you complete upper body mobility and you can carry a lot without really feeling it (I've taken mine with around 10kg on it).
It ventilates remarkably well. In terms of ventilation, the only other pack I've used that matches it are the low-rider Wingnuts.
Ya, the shoulder straps are cooler than a pack that sits on your back and they do give your upper body a lot more freedom of movement. I'm in the Southwest of the US so it gets pretty hot here too, but it's a dry heat--like an oven.
MTB Rider
I have a BD2. The ventilation is WAY superior to Camelbak. Ergon has redefined what a backback SHOULD be ... a hip-pack with shoulder stabilization. The weight just disappears.
When walking the only parts that touch the body are the waist belt and the harness. When riding most of the pack still doesn't touch your back and the ventilation is stellar. I rarely use the integrated rain cover, but It has come in handy at times. And the clever use of the back panels gives you ride accessible pockets.
The newer BC2 looks like the actual bag portion is inspired by the Camelbak blowfish. They have also integrated a "hip pocket" into the bag for easy access to your tools.
Get one. And move your Camelbak bladder into it. Or wait till the new and improved Camelbak bladders come out this fall.
Premium Member
I've got an old BD1, works great. Keeps the weight off my back and on my hips, no more back and neck pain for me after a long ride.
I've had my eye on this pack for a while. I am curious how you go about cleaning it. With my MULE I can just chuck it in the washer and it is good to go. This BC2 has a pretty hefty looking frame and I wouldn't want to throw it in the washer. Does the pack detatch from the frame? What do you do once it gets the MTB funk?
Ergon Bike
No the pack does not detach from the frame. To clean it, the best option is to spray it down with warm soapy water then wipe clean with a rag or cloth towel.
The BC2 just became available in the USA last week. Available here right now......in the hands of retailers in about 1 more week or so.
Jeff K
Ergon USA
Jeff K
Ergon USA
Thanks Jeff.
When is the team edition going to be available? I dig the lime green!
willtsmith_nwi said:
Being 280# and having fallen on my back with it, I can definitely say ... nothing.
Nothing happened to the bag? Frame looks pretty stout but I could see that pivot as a possible weak point. Then again...could be a moot point since I am sure the parts are easily replaced.
MTB Rider
I'm sure there is some force that will shear the ball joint fixing bolt and pancake the frame. Howevr, at that point you will have more serious trouble than your pack.
BTW, Ergon has excellent customer service. I had an issue with mine and Jeff fixed the remedied the issue in record time.
Just got the BC2 - packed it and checked the options to attach protection with the straps.
Before I got the bag I was wandering how they work...well...they work:thumbsup:
the main compartment of the bag is very organized but I would have liked to have zipped pockets inside.
I carry quite a lot of stuff for basic rides and you can see there are five pockets which keeps the compartment well organized and there is plenty of room left. There are also the back pockets, side attached pocket and a flat front pocket which I find useful for the rain cover and gloves.
I haven't ride with the bag yet, just adjusted it on my back and it feels very comfortable, the free movement of the shoulders is great and the weight of the bag almost unfelt.
I have the Low-Rider Wingnut pack and love it. Haven't been using the waist strap though, but still feels decent on my back.
With the Ergon packs, how snug would you cinch it up around the waist until the weight on the shoulder straps drops significantly? And with the waist belt cinched up, does it feel restricting in any way, esp. when leaned forward a bit? I figure this would increase the sweat buildup around the waist area. I get enough sweat around there as it is. Shouldn't be a huge problem, but something to consider.
This seems like one of those things you'd have to definitely check out in person to get a good feel for how it rides on the back. Gotta see if I can find someone locally that stocks these if at all.
BTW, thanks for the great pics! :thumbsup:
Five is right out
The waist belt does not feel restrictive at all- you're supposed to put it over the bones in your hips, not your waist. Same with the Wingnuts.
I have not noticed sweat to be any more of a problem than on my Wingnut- they are about equal there.
1 - 20 of 22 Posts
