I'm getting back into the sport and night riding after being away for a long time. I used to have a Vistalight system with just a helmet mounted light. I didn't like the added weight on my head and being tethered to a large battery. I'm sure things have changed a lot since. I need some help being pointed in the right direction.
I want to spend no more than $500 per light. I thought of getting one light for the summer and then another in the fall. If you have only one light should you get helmet or bar? 2 hrs run time is all I need. I also want something light weight, relatively small and easy to mount on or off the bike or helmet. I also tend not to use a hydration pack in the summer especially for shorter rides I'll just use bottles and cages.
Having said that I like the Piko so far as a helmet light since it seems easy to put on or off the helmet. I'm also looking at the glowworm xs. The larger Lupine systems I think are too much $$. Any other systems I should consider without getting bogged down in choices and light geek tech stuff?
