What do you use when replacing tubes or tires?
i also always use baby powder in my tires..TREK'ed-out! said:Well, I guess I'm off to get me some talc.
http://www.biketoolsetc.com/index.c... Kits and Supplies&tc=Tire Talc&item_id=RE-63http://www.worldclasscycles.com/tubes_adhesives.htmDenisovich said:Just be careful of which baby powder you get.
Much of the baby powder is now cornstarch, not talc. When cornstarch gets wet, it will dissolve (and things will grow in it.)
As a side note - is there anywhere to get unscented talc?
Thank you. Baby powder scented gloves after changing out a flat aren't a good thing.Jesse David Smith said:http://www.biketoolsetc.com/index.c... Kits and Supplies&tc=Tire Talc&item_id=RE-63http://www.worldclasscycles.com/tubes_adhesives.htm
http://www.branfordbike.com/tires/tire6.html#item3
powder smell is better than baby butt smell!Denisovich said:Thank you. Baby powder scented gloves after changing out a flat aren't a good thing.
And it will grow old on you as it's freaking difficult to wash off your hands...Lost81 said:A long time ago, I used powdered graphite instead of talcum powder. It had the advantage of retaining it slickness even after water has gotten into the wheels (e.g. from stream crossings). The problem was that it retained its slickness too well. You will never get a patch to stick to the tube after a flat![]()
Baby/talcum powder's not a good thing to breathe in (you're actually not supposed to use it on babies for that reason). I use straight Corn Starch, have had no difficulties whatsoever with exposure to wet.Denisovich said:Just be careful of which baby powder you get.
