B screw busted allen head off in it?
663 Views 5 Replies 5 Participants Last post by  Dave Mac
I was cranking down on the b screw and the allen head (park tool t handle) broke off and is now lodged in the head of the screw.
My thought is dremel a slot for a flat head screw driver to get the screw out and replace the screw.
Any other tips or tricks to doing this??
thanks
1 - 6 of 6 Posts
If the head is exposed I'd use a pair of pliers (vise grips, or knippex) and back it out with that. Easier than using a dremel, and it still leaves you with that option.
  • Like
Reactions: 1
The end of the Allen wrench is stuck in the screw?
I would first try spraying some WD-40 or something on it and try to tease the busted wrench out with a dental pick or something similar.
Then I would try what dysfunction said.
Then I would try the "cut a slot in it" method but, if possible, use a hacksaw blade since the Dremel could wander around and scratch up the derailleur. Probably a good idea to mask it off with duct tape to prevent that in either case. This could actually be pretty difficult since the Allen wrench is made of much harder metal than the screw.
  • Like
Reactions: 2
This is why I don't use ball end Allen wrenches.
The T-allens don't have a ball end, maybe op meant p? In either case though I've never busted a ball or straight allen that I can remember, must have been really torqueing on that b-screw!
Dave- can you get to the screw with a mini vice-grip and just remove it?
  • Like
Reactions: 2
Nope, not enough head to grab on to , I took the derailer off and tried to go from the under side of the b screw with vice grips not enough room, I ended up being very careful and cut a slot in it and used a flat head and backed it out, and replaced it.
I appreciate the replies.it was a straight allen, about half the head broke in there,
1 - 6 of 6 Posts
