Maybe I just don't understand your brake situation properly, but rubbing problems with IS discs are usually solved with spacers on the brake adapter not the wheel. Or do you have a PM mount fork?
How thick a spacer are you putting on the hub? I have no idea if it poses any actual problem, but it doesn't sound correct to me to stretch the fork legs out wider and to run the wheel off-center too.
