My KHS came with this funky rear axle set up. its a rounded head sheet metal screw with a aleen head drive that fits into a sculpted half circle washer with grooves onthe back of it which makes contact with teh drop out on the frame.
Im finding this set up worthless in that the wheel shifts and this set up works like shlt with chain tensioners because the diameter of the bolt is far less then that of the holes in the BMX chain tensioner im using.
Is there a way that i can conver this axle to a conventional set up using a solid axle and nuts? The hub is a powertools OE SS hub that came on the bike. Thanks in advance...cheers
