Glad you decided to go w/ Avy. As Craig noted, he’s not a fan of solo coil setups and believes his hybrid is best. I have the hybrid setup (w/ burnished bushings) and notice almost no stiction as my air side is only 35 PSI. Given that you seem to like your current spring, and there’s a chance that your stanchion is scored internally, you should probably stick w/ the coil you have. There will be progression from the hydraulic bottom on out on the smashpot, and from the damper side (it’s filled w/ oil so air compresses above it creating an additional spring). Hope that helps!
