1 - 19 of 19 Posts
Slow Goat....
Has anyone used this before? Any comments or recommendations?
It looks like it is more effient to route the cable. Less cable and housing so less weight, but I think it would be negated by the weight of the Rollamajig.
THanks,
Been using them for years. Even have one of the original versions with the itty bitty sealed bearings. I believe they enhance shifting and of course get rid of the cable loop. Even Shimano used to use their own version on XTR derailleurs a few years back. Think I heard they got into a lawsuit with Avid as a result.
http://www.mtbr.com/reviews/Extras/product_20952.shtml
conjoinicorned
when i'm forced to run gears (my FS bikes) i ALWAYS use a rollamajig. i have used them for years, never ripped one off and they all work as good as new. the rollers are all still going good, i lube them once in a while.
fantastic investment for shimano derailleurs!
I use them on 4 bikes. Have never had an issue of them being torn off.
Shifts are a little crisper with deore and LX shifters, didn't notice a difference on my XT's.
Made a huge difference on my tandem shifting, and it is XT/XTR.
Don't touch me!
Use it only if you want smoother, quicker shifting.
No problems when I used it on my XTR RD. Now resides on my road bike with no problems. Never had it "explode" (it's called maintenance/pre-ride check wh once ile) or yank loose (if it yanks loose, your cable/housing loop would've pulled through as well --> cable tension holds everything together on both setups).
Highly recommend it for general trail riding with Shimano RDs.
I Love my Rize
Very little movement
Sideknob said:
The SRAM mech's have different cable routing with a plastic guide the cable slides over, there is no pulley like the Rollamajig has.
The cable slides very little on a cam.
See pic below. I'm looking for easiest shifting (lowest thumb pressure) and most positive shifts; think the Avid Rollamajig would work better or worse than a cable loop like I have now? I'm using teflon coated shifter cables btw.
PM Me for Wood Fenders
Nice idea, they are on sale at price point. I've just ordered new housing...If I cut too short, I guess this is a cheap and effective fix. $7ish
1 - 19 of 19 Posts
