FYI, the adapter never changed, just the caliper. The original 165mm calipers and current 160mm calipers both use the same adapter.
Further clarification - I don't believe the caliper changed (they did modify the aesthetics of it, but this isn't related to going 160mm)), however the spacers on the CPS were reduced slightly to solve the problem. If you contact Avid they will send you the right spacers to resolve the problem.Speedüb Nate said:FYI, the adapter never changed, just the caliper. The original 165mm calipers and current 160mm calipers both use the same adapter.
The different sized spacers were an answer to the problem of folks who had to purchase adapters to run the larger 185mm and 203mm rotors, since Avîd only made the larger rotors available at about the same time the new calipers came out.Roy said:Further clarification - I don't believe the caliper changed (they did modify the aesthetics of it, but this isn't related to going 160mm)), however the spacers on the CPS were reduced slightly to solve the problem. If you contact Avid they will send you the right spacers to resolve the problem.
I thought that the newer calipers for the 160 rotor came with the smaller spacers on the CPS; the older calipers had the larger spacers for the 165. And that this resulted in the calipers being identical, but you had to change the spacers to go between the 2 rotors? i.e. if you used the same spacers on both v1 or v2 calipers, they had the exact same spacing.Speedüb Nate said:So, yes, the 2.5mm difference between the 165 and the 160 was all in the caliper and not in the washers or adapter.
Well.... first off I would listen to Nate on the washer stuff as I'm pretty positive he's right and I'm wrong.Warp2003 said:At this point, Avid already "owes" me a rotor and a set of pads... and who knows, maybe a caliper. I've heard Avid has a good customer support...I just hope they extend their good customer support well below the border. Most manufacturers "play dead" when they hear Mexico.
A front on the rear would result in a 10mm difference, fitting a 140mm rotor, so that's not going to be it. I don't know where else to look.Roy said:Third, I don't know what the spacing would be if you had a front caliper in the rear but this would be the only other error I can think. .
