Avid Mech discs. - Can you one finger brake?
1498 Views 24 Replies 19 Participants Last post by  Legbacon
Ive become a one finger braker with my current hydr. brakes (Formula Evo 9.5) but am having second thoughts on keeping them as they care a pain to bleed, keep quiet, and heavy. Granted, when well maintained they have great stopping power and all controlled with one finger on the lever.
So my question is, can you get one finger control with the Avid mech discs?
Thanks.
1 - 20 of 25 Posts
I've got Avid with 6inch rotors.
For long downhills i usually use 2 fingers. I rarely use just 1 finger. But 1 or 2 fingers, no big deal...you get used to anything!
Yep. I'd have had my other useless, heavy fingers amputated by now 'cept I need something to hang on to the grips with.
Thanks.
Yes, I do..................
granted I use an 8" rotor up front. Your experience may vary.
Monte
Sure. Extended downhills are going to cause you some fatigue. But for the most part they are one finger brakes for me...
jd
Sure...
Yes. They can stop you with just one finger. Don't expect the soft lever feel of a hydro though. But they are more than capable to endo you with just one finger.
Never needed more than one finger with mine in the two+ years I had them. 6&6
Yeah one finger especially with the Avid Ultimate levers. I have the levers position so my pointer finger can pull right into the hook of the lever, and it is plenty strong to send you flying over the bars.
Thanks.
One finger of nice light effort is all I need. I test rode a few bikes with Hayes hydros a couple of weeks ago and needed two fingers and much more effort.
combination for me.
Had hayes 6" always 2 finger now 185 avid mechs and use a combo of 1x1, 2(f)x1 or 2x2 depending on conditions and if I have been paying attention. 230lbs.
I've never own a disc brake equipped bike but I've ridden plenty of other people's bikes. Since I started MTBiking which was 1999, I've always set my bikes up for one-finger braking.
Let's pick one bike I've ridden recently, someone's Epic front Hayes and rear Coda. Unfortunately my friend is not a lever-blade-tip braker like I am, so the Hayes lever forces me to use the center of the lever blade and I hate that. The Coda's while having poor modulation, have a neat and useful flattish lever blade profile.
All my levers have quite flat profiles for my freaky one-finger, lever-blade-tip gripping and late braking technique. (Freak!)
I use the extra leverage of lever-blade-tip braking to counter the use of only one finger, anyway it's all you really need. One finger+low-end V-brakes= I still stop properly and endo behind people at races on the downhill sections of the XC course.
A tip for setting up levers for my type of freaky braking is set the lever angle quite vertical. Instead of braking by curling your finger like a worm (which causes strain on long braking), you simply swing your finger back.
Because there is less strain, modulation feels easier and you feel more confidant with braking. (It works for me, not a STP fact)
Thanks to everyone so far for the great responses.
Capt_phun - if you dont mind me asking what did the your avid brake set up cost, assuming that you got frt and rear + levers? What cable housing do you run? Im looking for a complete set up so Im trying to gather as much info as I can. Thanks.
Ditto, 2 finger braking for the uber-steep stuff or rapid decceleration. 1 finger braking for everything else. 160mm rotors, 230lb.
I have started to ride larger rotors and really do see the benefits as a bigger guy.
I have the Avid mechanical disc brakes @ 203mm front and rear ($169.00 for the pair) with SD Ti levers ($39) and Avid Flak Jacket housing and cables ($20). That’s $228 total (plus any tax and shipping where applicable).
Let's just say that braking power is no longer an issue.
I had the same response to those Hayes.. After 1 run down the hill my hands were cramping up from trying to brake with those things. Either Hayes aren't all they're cracked up to be or something was seriously wrong with those demo bikes.
Me, too! One-fingering is all I need. (I'm 150lbs.)
Even when I used to have 6"/6", one-fingering was all I needed. (I now have 8"/8".)
By the way, I never noticed 8" to be "grabby" (as occasionally reported by some), even on the 1st day I switched to 8" from 6".
Never tried hydro myself to comment, but I'm too happy with my Avid mech to look elsewhere. ;)
Nah, the 8's aren't any more grabby IME. They just have more power.
I'll be that guy that disagrees with youse guys. I switched from a 165 front to a 185 front and definitely noticed the extra grabbiness/loss of modulation in the slow-speed technical stuff -- nothing that I couldn't makes some adjustments at the lever and inner pad to accomodate, but a difference nonetheless.
avid set-up
I purchased the avid ultimate levers from an online retailer, I think I paid like $119 or some outrageously high price, but they have been worth it in my opinion. The ultimates are not "springy" like the other avid brakes so it feels softer and smoother. I had the Avid Ti levers but your could feel the spring return the handle sharply and make that avid "clunk" as the lever returned. I spent the $$ on the ultimates, I look at it as an investment. They will last a long time and always feel great. The avid mech's came on my bike, and I really like there simplicity and ease of maintenance. I love my Marta hydros as well, but the avid are just plain simple, no brain breaks. Really I could never understand how people say they have problems with the mech's. They ARE that simple, if you can do basic wrenching,then the avid mech's are simple to use, fix, and adjust.
You can find mech's at a decent price on ebay or use the www.qbike.com search. Airbomb is also go for spare avid parts, like when I busted the outboard adjustment knob on a heavy duty fall on a rock.
As far as cables, I just buy the bulk 30meter roll of lined housing and run full housing from the lever to the caliper. I run a jagwire teflon coated iner wire, seems a little smoother, but in a bind I will use regular inner wire. I'm really not that picky, they bike and brakes work, its up to the rider is what I believe in and I don't think dropping $$30 on a cableset is a worthwhile spending since I replace the whole outer and inner cable hosuing and wire every year.
So i would say look on ebay for the levers and mech. It will set you back a little $$ and I would also recommend looking into the louise FR which are hydro and pretty inexpensive.
I'm not a fan of Hayes, yes they work and are easy to adjust and bleed, but personnally I never like the feel at the lever. Not saying they don't work, they do just fine, bt just never got into them. And the hayes mech's are just pieces of metal poop compared to the avids
I got a set of mechnicals on my stock VT3, not changed a thing on the set-up, 6" rotors, stock levers. I have to 1 finger now if I use 2 I tend to overpower them a bit.
1 - 20 of 25 Posts
