I agree with Jdub.
I ride at the sorroundings of Mexico City where each and every trail make you spend a lot of time climbing just to gift you with long descents.
When using my 160 F/R mechs, the rear got some overheating (aparently I was not sending enough cooling air to the rear) and I wished for either a more powerful front to ligthen up the workload of my rear brake or a full 185 F/R setup.
I'm 150 (in riding order) btw, not heavy precisely.
At singletrack speeds and normal climbing/descending conditions, the 160 are enough to send you OTB in any situation, but on long, long descents, you'll like a bigger rotor to get some heat off.
Another option is to run Koolstop's or Galfer's pads. Those are semi-metallic (a la Hayes/Shimano/Magura) and do not generate as much heat.
Go for the simple approach. Switch pad compound, if it does not work go for bigger rotor front and if that is not even enough (?? - Avids are all about usable power) go for both bigger rotors.
