Completely new here, and completely new to disc brakes! I've just retrofitted a second hand Avid Juicy 3 rear disc brake to a very good steel frame bike using an A2Z MTB disc brake frame adaptor. It's completely solid and works well - no leaks, pistons are smooth and braking is good.
When compressing the lever, there's a good solid point where the pads connect with the disc. This works fine in terms of braking when riding. If I keep the lever compressed it very slowly travels to the fully closed position against the handlebar. It is really slow, and the brake really is solid, but is this right? I bled it really carefully, de-gassed the fluid and got rid of all bubbles, and like I say there's no leaks. What's likely to be the cause of this?
