Hey guys,
My name is Max and I´m a cyclist from Germany. Since I have some serious problems with the bleeding procedure of the Elixir CR breaks- and not even one user of a german board was able to name a solution, I decided to log on mtbr- so here I am
The problem is, that there is no way for me to press break fluid through the lever of the break!
After preparing the standard bleeding procedure by turning all adjusting screws to their upper limit position, I tried to press fluid from the brake up to the lever but it blocked- I dissembled the hose and opened the cylinder section of the lever: It seems that their is no way for the fluid to pass the cylinder sealing (what I am sure it should)
Does anyone of you knows sth. about the issue or am I just to dumb to bleed a disc break?
Thanks for your answers and excuse the vocabulary
greetings
max
greetings
max
