So, I installed my Codes on my bike about 3 months ago. Trimmed the front line down with a Jagwire hydro-line cutter, and installed a new fitting. Re-installed everything per manufacturers instructions, bled the brake, and everything worked fine.
About three weeks (and two rides) later, I grab my bike and flip it upside down in my garage. All of the sudden, the rear brake lever sinks all the way to the bar. I figure that since I only bled the front, that the bad factory SRAM bleed to the rear brake probably left some air in the line, so I bleed it and it works great. I ride it 4 or 5 times over the next month, and no problems. Everything is perfect.
Flash forward: the bike sits on my patio for about 3 weeks without any riding or movement. I go outside, and I'm fiddling with my bikes. I pull on the front brake lever, and the lever sinks all the way to the bars. I check the rear, and the rear is perfectly fine. The bike hasn't been ridden, jostled, or moved in over 3 weeks.
I've bled Hayes and Avids before and I've never had this problem.
Are their pockets inside the Code calipers/levers that can trap massive air bubbles? Or has anyone else found that they leak air into the lines?
I can't figure this out.
