Has it recently been serviced by a shop? Perhaps somebody lost the screw and replaced it with another.
No, I bled the brakes and evidently did not screw it in tight enough.XSL_WiLL said:Has it recently been serviced by a shop? Perhaps somebody lost the screw and replaced it with another.
Nope, I took the silver screw out to bleed.vk45de said:that "other screw" looks like a plug to me - which is the same as your normal screw. didn't you have to get it out when you bleed?
This is getting crazy.fixbikeguy said:That black screw is not supposed to be there...not sure what's going on. You could not have bled them with that there. Where did the silver one go?
um.... yes. :madman: DOH!dmcgoy said:That's the caliper screw - it's smaller than the lever screw but still fits. Does you caliper look like you have a larger screw than normal?
