Strange problem I'm having. I recently picked up a new Avid Professional Bleed Kit. I used it once to bleed my front and rear brakes, and when I was done, rinsed all the bleed kit parts with water and dish soap. Then the hoses completely clouded up. Not just cloudy, but completely opaque. I thought at first that it was just condensation in the hoses, but left it to sit for a week with no change. Tried flushing with rubbing alcohol - no change. Blew compressed air through the hoses - no change.
Has anyone else had this problem? Any idea of the cause? It basically makes the kit unusable since I can't really tell if there are any bubbles left in the line or even where the fluid level is. I called SRAM and talked to tech support. The guy had never heard of this problem (although I am not confident he completely understood what I was trying to describe) and had no solution or recommendation other than "take it into your LBS."
Here are a few pics so you can see what I am talking about.
Here I have removed one end of the hose from the hose barb - under which the hose is still clear.
Here I have stuck a small screwdriver in to show that is it is not just hazy, but totally opaque.
This kit was not cheap and as I mentioned, this happened after the first time I used it. I was thinking maybe the hose section is replaceable, but the opposite end of the hose (the end that screws into the bleed port) is not removeable from the fitting.
Anyone have a similiar experience?
