I got that same kit too.MitchD said:I bought mine from bikebling last week for $29.95,I do not know what year it was but it included two hose ferrules,two barb hose fittings,8mm crowsfoot wrench,a L shaped Torx wrench,two syringes with hoses and clamps, a bunch of pad spacers,a piston spreader, a 4oz bottle of DOT4 fluid,and instructions in every language including gibberish.
Yea, that what I figured but I would not put it past a company to change the sizes of the ports to make the old bleed kits obsolete.frdfandc said:Only difference is a new box label. Just like everything else, the new model year stuff is always more expensive than last years stuff.
I doubt Elixir 5 REQUIRES 5.1...Bikebr said:Anything about DOT 4 x DOT 5.1? An Elixir 5 requires 5.1.
You are correct. But Avid recommends DOT 5.1. You can pick it up at any automotive store. Its readily avail there. Its also included in the Avid bleed kits.Uncle Six Pack said:I doubt Elixir 5 REQUIRES 5.1...
Been looking at this myself as I get ready for spring (for my Code 5s)... DOT 3, 4, and 5.1 are all compatible with each other chemically. They have different boiling points, though. I am having a hard time finding 5.1 around here (seems to be a specialty fluid for racing applications, maybe) so I will probably just go with DOT 4.
If any combination of small rotors/clydesdale rider/long descents applies to you then 5.1 may really be worth it. For all my bad braking habits, I have never had a worry of the fluid boiling.
"wet" DOT 5.1 boils lower than "dry" 3 or 4... so I figure I will go with what is readily available and do a flush once a year or so along with a bleed.... not too bad when the entire brake system can be flushed with a few ounces of fluid.
Maybe you have heard (or maybe not) DO NOT use DOT 5, it is very different chemically and will probably cause serious problems.
If I am off base here on anything, I hope someone more knowledgeable will chime in.
Frdfandc and Six Pack,frdfandc said:You are correct. But Avid recommends DOT 5.1. You can pick it up at any automotive store. Its readily avail there. Its also included in the Avid bleed kits.
But you can use DOT 3 or 4 as well in the Elixers without issue. Though I'd recommend using DOT 4 if 5.1 can't be found.
Just make sure to get a small bottle as brake fluid is hygroscopic and will absorb moisture over time. So a large bottle of brake fluid will go to waste, unless you like bleeding your brakes often.
DOT 5 is silicone based as where DOT 3,4, and 5.1 are polyethylene glycol based.
Just a follow-up... I have a high-quality DOT 4 (Valvoline I think) now. But it is "synthetic".... any worries there on compatibility with whatever is already in my system? Or are all brake fluids synthetic these days?frdfandc said:You are correct. But Avid recommends DOT 5.1. You can pick it up at any automotive store. Its readily avail there. Its also included in the Avid bleed kits.
One trick we used to use in my old photographic chem process storage was to put glass marbles in the bottles to keep the fluid at the top. This minimizes any air exposure. If you have some moderate size SS ball bearings laying around doing nothing, they would work too.frdfandc said:But you can use DOT 3 or 4 as well in the Elixers without issue. Though I'd recommend using DOT 4 if 5.1 can't be found.
