rkowalick said:
I think torque will be more noticeable than heat dissipation
Depends, really.
Back in the day, I upped to a 185mm front rotor when it first became available from Avid (I was running a V in the rear at the time).
My sole motivation for the rotor swap wasn't power, but heat. One of my regular rides descended me 2,000' over 5 miles. At the same point on every descent -- about 1.5 miles in -- my front 165mm rotor began howling so loudly that I'd back off the brakes, just to spare my sensitive eardrums. The power was sufficient for me, but the noise was gawd-awful and probably echoed for miles.
Being new to discs, I thought it was due to the dust at that particular section of the trail. But an Avid tech took one look at my rotor, and diagnosed heat buildup as my problem, citing the tell-tale rainbow discoloration.
Bumping up to 185s cured that problem instantly.
The extra power was noticable, but for the most part, the 165s were sufficient. In fact, the larger rotors were most noticable in slower speed, techincal trails, where they were more difficult to modulate. Naturally, it was something I quickly adapted to (and all the various adjustments on the Avids & Speed Dial levers help to tweak it).
