Just was doing the LAST THING on installing my new WB Fluid 130 fork and was brought to a screeching halt when I found that my Avid BB7 disc brake adaptor, when bolted up to the inside of the fork's brake tabs, does not line up the caliper with the brake rotor. Sure, the bolts go thru the fork tabs and screw into the brake adaptor, but the fork tabs are way too far away (outboard) from the disc rotor for the brake caliper to drop onto the rotor. Like over 5mm too far away with the caliper slid as far over inboard as it's positioning system will allow. I would have to put about 7mm worth of spacers between the fork tabs and the Avid brake adaptor to get the caliper to line up with the rotor, not a good idea.
Very strange, as the WB IMV 100 I am replacing had the brake mounting tabs in the exact right place: the caliper's mounting bolts were right in the middle of the slots that allow for inboard/outboard adjustment.
Anyone else have an issue like this with these forks?
29erchico
29erchico
