I weighed J3s and BB7s (including brake levers) and the BB7s were lighter. Maybe the J3 caliper is a little lighter than a BB7 caliper, but decent mech levers like speed dial 7s are gonna weigh much less than J3 levers.Rufudufus said:The Juicy 3 will be a little lighter
juicy3smazho said:I'm going to upgrade my brakes. I'm looking for good cheap disc brakes. In yours opinion, which is better buy, mechanical disc Avid BB7 or hydraulic Avid Juicy 3?
Avid Web Side:eminefes said:I weighed J3s and BB7s (including brake levers) and the BB7s were lighter. Maybe the J3 caliper is a little lighter than a BB7 caliper, but decent mech levers like speed dial 7s are gonna weigh much less than J3 levers.
its really not. replacing cables is probably harder.. which says a lot, because replacing cables is incredibly easy.scooter916 said:installing new cables is much easier than bleeding
I could have both cables replaced by the time you find your bleed kit!!tomsmoto said:its really not. replacing cables is probably harder.. which says a lot, because replacing cables is incredibly easy.
By the time you size the several pieces of housing, install all the end caps, stretch the new cables (even pre-stretched cables need a little more stretching), and do final adjustments to the mechanicals...I'll bet I can have my Juicy 5's bledscooter916 said:I could have both cables replaced by the time you find your bleed kit!!
all you need is a 5mm wrench and cable cutters and a lil lube or grease
