1 - 6 of 6 Posts
Not sure what to type?
Cool
Thanks for the info, I've only had bearing issues one time in the many years of using Frogs but the replacement parts are pricy. Be sure to let us know if you find a cheaper outlet for the plastic bodies:D I've broken 3 and they cost $50 a set and you can't buy just one.
Weird huh?
Good info, thanks !!
BTW Hecklerboy:
Pathetic attempt? Au Contraire' Nice job! Last month I was facing the possibility of being in WV on business. I had your site flagged for info. Turns out, I never went. Too bad.
Folks that take the time to keep our sport in the forefront are always doing good.
Cheers,
Mike
Discussion Starter · #4 ·
Great :rolleyes: I cracked one half of a pedal body recently. Thankfully I had an old pair I was able to cannibalize. They're still the best pedal I've ever used.
Discussion Starter · #5 ·
cmdrpiffle said:
BTW Hecklerboy:
Cheers,
Mike
Thanks for the comments. I just updated with some pics from the Slatyfork Shuffle 2006.
Yup
Allways save those usable parts from old gear; the first two bodies I broke cost me nothing because I saved the bodies from a set that I didn't properly lube on which the bearings disintigraded and damaged the spindles.
1 - 6 of 6 Posts
