Well, took the plunge to convert my triple shot from lux3's to ssc p4 U2 emitters. Everything was going fine, in fact it had been one of my easier mods. Soldered the emitters up and checked with multi meter; all lit (seperately). So I mounted them up in the cateye and after getting them put in, 2 of the 3 leds won't light. Any ideas? Hooked up the batt and turned it on very briefly to check if the circuit was open. Same single led lit up... Now this has me really confused. I've damaged the wires under the dome going to the die before, but if that was the case then none would light. Maybe I have poorly insulated slugs? Any other ideas? I'm :madman:
