Hmmm... I'm sure it does exactly what you say it does, simply, effectively and inexpensively. But being occasionally challenged as I am, I'm not sure I understand just how you employ the tool, even after seeing pictures & reading your blog describing its use. Guess in this case I'd need to see a video.unit said:
I would say both have their place...I just could not get a wrench in there...even after modified to the hilt...guess I am the one who is challenged.Sparticus said:Hmmm... I'm sure it does exactly what you say it does, simply, effectively and inexpensively. But being occasionally challenged as I am, I'm not sure I understand just how you employ the tool, even after seeing pictures & reading your blog describing its use. Guess in this case I'd need to see a video.
Lucky for me I've found that an allen wrench can be bent slightly to allow adjustment of the bearing preload ring witout removal of the rotor adapter.
I don't claim one way is superior to the other, I'm just sayin'...
--Sparty
I think the reason this was done is to widen the flange spacing as much as possible.marinrider said:This looks like a pain in the a$$! I've been thinking about getting some new wheels this winter, and thougth I'd splurge for the King hubs, but now may have to reconsider.... I wish King made an ISO rear SS hub....
That frequently? Ouch. There was a time when I was tightening it quite often, but never as much as you. I haven't had to do it recently, so maybe it's all settled in.smudge said:Looks like you guys put quite a bit of though into this. I just trimmed my 3/32" allen down with some snips and a grinder. Fits right in and I don't have to remove anything. Perfect for keeping with me since I have to tighten the cone every other ride these days.
i've been able to orient the allen wrench in such a way that I can use it as a lever to tighten the lockring before tightening the allen bolt. It's a pain in the sack for sure, but possible.Drevil said:That frequently? Ouch. There was a time when I was tightening it quite often, but never as much as you. I haven't had to do it recently, so maybe it's all settled in.
BTW, don't you need to tighten the ring by hand before you lock down the bolt? It's been a while since I've done it, so maybe I'm not remembering properly, but I thought the adapter is in the way. How do you get leverage (or even reach it) with the adapter still attached? Or is my memory fading?![]()
Ditto on the trimmed allen... fits like a dream.smudge said:Looks like you guys put quite a bit of though into this. I just trimmed my 3/32" allen down with some snips and a grinder. Fits right in and I don't have to remove anything. Perfect for keeping with me since I have to tighten the cone every other ride these days.
