Handspun/QBP already makes a premade wheel. Getting this package would be as easy as going to yourr local QBP dealer and ordering.
Enabler is actually a rear brake setup...FYI. I haven't looked into which adapter would allow it to work with a 135mm front hub setup...chequamagon said:Here is what you need:
Salsa Enabler Fork, QBP PN FK0515 - $120
Handspun Surly/Vicious wheel, QBP PN WE7332 - $200
Surly Larry 120 TPI tire, QBP PN TR0002 - $110
Surly 26x4.0 tube, QBP PN TU0003 - $17
Rox wide rim tape, QBP PN RS0002 - $14
This setup takes a normal front brake, and would work on 29ers designed around 80mm of suspension travel.
Bear in mind because it is intended for a rear, therefore the dropout is for a 10mm not a 9mm axle.jncarpenter said:Enabler is actually a rear brake setup...FYI. I haven't looked into which adapter would allow it to work with a 135mm front hub setup...
Is the WE7332 Handspun wheel centered or offset?chequamagon said:Handspun Surly/Vicious wheel, QBP PN WE7332 - $200
Centered.slimhazy said:Is the WE7332 Handspun wheel centered or offset?
Cool, thanks.JAG410 said:Centered.
Are those Large Marges or the Vicious rims mentioned in the post above?mtnbykr©™ said:you'd need a gazzilodi 3.0 on the back of a 1x1. you'll need to cut off the brake bosses also. i have 2 of the 3.0s if you're interested...
