I just got a frame w/ a 5th air (I have read all posts, this is a new question), and When I connect pump (brand new "buzzy's pollinator") no air registers at any point from when I connect the pump untill it is bottomed on the threads on the shock. I can add air to the shock, but It only takes 3 or so strokes to get the correct psi (I am 220, so I use about 120 IFP and 150 main). The shock feels great so far, but I am wondering whether or not my pump is bad, or if there is something goofy with the shock, b/c It doesn't make sense to get it from "0" psi all the way up to 150 in 3 pumps.
Another thing I tried, is after I hit the release valve on the pump, then took it off (pump still reading zero), I stuck my finger onto the valve core to see if any air was left in the main chamber, and sure enough, a bunch of air is coming out. Then, to get it back to the right feeling, I have to keep pumping up to 150, hitting the release button on the pump, and keep going until the shock is as firm as it was originally.
So am I correct in thinking that my pump is bad, or what? Thanks for any help in advance. For anyone who is looking at buying this shock, it does work GREAT. I am just being careful.
