www.pushindustries.com The only way to get stable platform out of a normal fox shock.
Some bikes are designed around a zero sag setup (Giant NRS) but they are harsher than other FS bikes. Sag is required for just about every other suspension design to run properly. The AVA volume control will change the ramp up of the shock as it sinks deeper into the end of its stroke. If you overinflate the shock to eliminate sag it won't matter what the AVA is set to because you will never even be getting past the initial part of its stroke.
