1 - 20 of 28 Posts
Does anyone have any input on the Atomlab Quickstep pedals? I've heard some general good things about them, but I havn't heard any solid reviews. Also, I havn't heard anything about the clipping ability. I'm specifically wondering if they are easy to clip in/out, do they provide any range of motion, .etc. Can anyone enlighten me and everyone else who is wondering about the Quicksteps?
Great Pedal for DH
I use the Atomlabs on my DH/FR bike. The '06 models of these pedals look awesome from the pictures, but I am using the '05s. These pedals are completely different from any other clipless pedal on the market. It's hard to describe, but basically they ride like platforms until you pull up on the pedal. So they are really easy to get out of. The clips don't really hold onto the cleat until there is upward force. Another great thing about these, is that you can clip in either direction. That is by sliding your foot forward or backward. I have actually found it's a little easier to slide in backward. Another thing is the clips are spring loaded and if you are not cliipped in they will push down and you will still get a good grip on the platform.
These pedals were require that you have flat bottomed clipless shoes. I know 661 makes some, and the Shimano DX downhill shoe is like that too.
I wouldn't trade these pedals for anything for DH/FR. They may be a little too much for XC riding. They may also work for AM if you want the stability of a platform.
oldschoolbiker would you be able to expand a little, why don’t think they’d be suitable for XC riding?
This is the first decent info I’ve come across on these pedals.
Well the main concern with using the pedals for XC would probalby be weight. Most XC riders are really concerned with weight. They are probably twice the weight as lightweight XC clipless pedals. And for me it's overkill for XC. I mean for myself, when I'm riding XC my feet basically just stay clipped in the whole time and there isn't much real advantage in having the platform.
Now if you will be riding technical terrain where your foot could pop out (or if you want your foot out) and you want good grip on the pedals when you are not clipped in, then these will work perfectly. Actually a friend of mine rode my bike on a Downhill run and used regular shoes. He said he could feel the clips under his feet but he had no problems with pedal grip.
Another amazing thing about these pedals are their simplicity. It isn't a complicated design at all, but it works great. It's easy to take the entire pedal apart for servicing, and all the platform pins are replaceable.
Also let me repeat this warning, you must have flat bottomed shoes.
Shoes like this WILL NOT work: http://www.jensonusa.com/store/product/SH602B00-Sixsixone+Peak+Shoe+05.aspx
Something like this MIGHT work:
http://www.jensonusa.com/store/product/SH602B03-Sixsixone+Nuevo+Shoe+05.aspx
These definately work, this is what I have:
http://www.jensonusa.com/store/product/SH500B01-Shimano+Sh-Mp66+Mtb+Shoes+06.aspx
Thanks for the info dude.
I'm after pedals which you can ride clipped and unclipped, so when I hit the north shore\technical stuff, I can unclip and not crap my pants about been stuck in the pedal.
I'm using mallets at the moment and I'm not keen on them.
I've got these shoes; so it looks like I'd need to buy a new pair.
http://www.beyondbikes.com/bb/ItemMatrix.asp?MatrixType=1&GroupCode=SH-SID-Dragon
Yeah those shoes won't do it. You'll need some with soles similar to the one's I posted.
The mallets suffer from the same problem almost all the clipless/platform pedals suffer from. When you are uncipped the shoe will not grip the platform because you are sliding around on the clip. Also part of your problem with the mallets are the shoes you are using.
The Atomlab pedals are so easy to unclip when you want, you'll ride the North Shore style stunts clipped in. I do and all my friends think I am nuts, if only they knew my secret.
From what you describe the Atom labs will definately be what you want. My friend said he had no problem sticking to the pedals when he rode with regular shoes, and that was on a Downhill run with 1000ft vertical descent. I think I saw speedgoat had the 2005 models on clearance, but the 2006 models definately look awesome and may be worth the extra $$$.
Here are the links to speedgoat:
2005 http://www.speedgoat.com/product.asp?part=109569
2006 http://www.speedgoat.com/product.asp?part=117385
Float and Versatility
macace8 - thanks for the thread, as I'm one of the "everybody else" who wondered about these, and oldskool, thanks for, as macace8 said, some of the only helpful info to be found on these pedals on the web (an email I sent directly to Atomlab about the pedals went unanswered as well).
Oldskool (or others), another poster on another thread said this about the Quicksteps: "From what I've heard, they are as good to ride in regular shoes as they are when you're clipped in. However, beware, that these pedals do not have any float - you clip in and your foot is held from rotating by the pins."
Is that comment about "lack of float" accurate, and does it matter? Should someone like myself with no clipless experience try a pedal with more "float" to begin with? The 2006 version of the pedal is advertised as "Cleat will engage pedal from any direction, 13/17 degree release angles" -- if that has any bearing on the float question.
I bike commute, do technical singletrack, and will be doing some more downhill-type riding later this summer. Seems like a versatile pedal, good with "regular" shoes (like grippy five-ten impacts) or the shoes you suggested oldskool. Was thinking something like Tioga MX Pro platforms with grippy shoes to replace basic cage pedals have now, but this seems like way to try clipless and still have platform fallback with decent pin placement and grip.
Anyway, thanks again!
genny,
I would say that is an accurate statement about float. These pedals have no concept of float. It's a completely different design and float isn't applicable. It's like asking what kind of float platform pedals have. They have none. These pedals ride like platforms except when you pull up on the pedals your foot don't come off. You have a few degress you can move your feet around, since the release angles are 13/17. But your foot cannot freely move around like normal clipless pedals. Your foot is securely on the platform, and the platform is partially holding your foot on the pedal, especially on your down stroke. These clips grip tighter when there is upward force on the clip.
Another thing, I would say these pedals ride good with regular shoes, but not as good as normal platforms. It does take a certain amout of force to push the clips down out of the way, and you can feel the clips pushing up on the bottom of your feet.
For the purposes you are planning to use the pedals I think they would be a good choice. Only downfall with them is that they are expensive and a little heavy (2006 version is ligher than 2005 though). If you went straight to these and bypassed normal clipless pedals, you will think normal clipless totally suck if you ever try them.
I still use the normal clipless pedals on my XC bike because of weight and the fact I basically never need to unclip while riding. But I absolutely love these pedals on my DH/FR bike.
I looked at these pedals with interest some time ago.
As someone who struggles to get out of pedals in emegencies I run flats at the mo when doing a propper MTB ride, but Id rather be clipped in, esspecially now that I ride a road bike too with Crank bros road pedals.
In years gone by I ran old style clips then Powergrips. If I want to do an MTB ride clipped in, I have Mallets. These are dissapointing in that I still cant get out in bail, and riding these not clipped in is NOT an option what ever anybody else says.
It seems there are 3 types of Quicksteps I could chooses to buy:
http://www.allterraincycles.co.uk/product.php?pid=100598
http://www.chainreactioncycles.com/Models.aspx?ModelID=11410
Or 2006:
http://www.wiggle.co.uk/?main=ProductDetail.aspx&ProdID=5360023041&referid=Frogoog
I have to say that the older pedals looked like they offered the best grip when not clipped in, but If I was to buy with out being able to test, then Id prob go for 2006 in the hope that Atomblab new waht they were doing and that newer meant improved for some other reason.
One comment worries me though. It has been described as a pedal that holds onto your foot even stronger the more you pull up (this is what I do wrong in a pottential bail and Im not gonna change now). I need to know that these really are the easiest to get out of in an emergency even when youre as useless as me when it comes to clipless, before I buy yet moe pedals.
Ive tried and gone on to sell most clippless on the market over the years, so would like to hear more on peoples experiences using this pedal if there are any thanks.
I Have Gnarly Potential
Because of the way the clip is made it seems it would not let you out by pulling up even if you did it really hard. but you should never expect a clipless pedal to ever let you out that way, always get use to pulling out the side :/
That 2006 pedal doesn't exist! I ordered the 2006 pedal and it’s exactly like the 2005!
Xr600 you’d be better off buying them from the States, I paid less than 50% of the UK price.
The only time my foot came out was pulling up; but I can't be 100% sure I was clipped in, coz I’m not used to them yet.
I found unclipping to be the same as shimano and crank brother pedals.
These Pedals are absolute quality, you won’t be disappointed.
I know this is bringing a dead thread back to life. But the 2006/2007 pedals are not available yet. I ordered the 2006 pedals from speedgoat, and I was sent the older style. Before I returned them I e-mailed atomlab to ask them whats the deal. Here is an e-mail from Mike at atomlab. This was sent to me on Nov 2.
Delmar,
The new Quiksteps aren't available yet. It will probably be February or so before they are available. I would return the 04/05 ones to Speedgoat.
Best regards,
Mike
Frothing Loony
oldskoolbiker said:
I don't think they will work too well. Out of all the links you send me in e-mail I think only the Shiimano MP66 will work well. These are the shoes I am using, here is the link you sent me:
http://www.chainreactioncycles.com/Models.aspx?ModelID=7610
Other shoes which will work well will be the:
661 Launch SPD
661 Dually SPD
Sorry to revive a dead thread but there is something I must point out. Oldskoolbiker on the above advice I bought 661 Dually SPD's to go with my new atomlab quicksteps and guess what, they AREN'T compatible!!! That's 60 quid down the toilet based on carelessly given advice, people please please be careful of your facts before posting advice, I've learnt my lesson for now, expensively, but with a little more care this loss could have been avoided.
As far as I can see in order for the shoes to be able to clip in to these pedals they cannot be set in to the sole, they have to be bolted to the bottom of a flat sole which to my mind will make them as clunky as hell when trying to walk on them, honestly I should have stuck to shimano :mad:
Phil
Phil
Phil,
I really don't understand what you are describing. If the cleat is too deep into the shoe it will not be able to clip into the quiksteps. This is why you need the flat bottomed type like 661 makes. The cleat of the quiksteps are pretty big so you might need to trim some of the sole off around the cleat. Why don't you post some pictures? I mean seriously the shoes should work, I mean the example shoe they show in the quikstep owners manual is a 661 shoe.
1 - 20 of 28 Posts
