1) Is the Atlas frame powdercoat or anodized???
2) How much did Ibex change the frame dimensions from Azonic's design???
3) Does the posted target weight of 28lbs apply to the base Atlas or the Atlas Pro???
4) What size frame does the target weight of 28lbs include???
5) Will you have pictures of the 20.5" frame because I want to see if any of the dimensions look grossly distorted.
The only reason I ask about the 20.5" frame is because thats the one I will most likely get with my 6'-2" 34" inseam build. Again, thank you all for the time you devot to answering questions especially Jack.
Later,
Sean
Later,
Sean
