Did some searches but couldn't find any discussion of this specific concern.
Given the fixed orientation of the spokes in a straightpull hub, how concerned should a builder be with the shift in spoke angle when lacing the straightpull hub to an asym/offset style of rim?
Some offset rims have pretty significant offsets of 4.5mm or more. Compared to a center-drilled rim, the change in spoke angle with a 4.5mm offset is ~ 1 degree. FWIW, you could encounter a similar difference in angle if comparing a 26" rim to a 29" rim.
My conclusion is that one degree change in the spoke orientation isn't enough to meaningfully impact the wheel structure . . . ie, no more likely to cause fatigue/failure where the spoke exits the hub.
But curious in the opinions or experiences of others.
